Financial Releases
RFMD(R) Expands Broadband Transmission Product Portfolio; Enables Enhanced Bandwidth-Driven CATV Services and Advanced Fiber Deep Architectures
The D10040300GTH hybrid power doubler amplifier module is specifically designed for CATV infrastructure applications including line amplification and hybrid fiber coaxial (HFC) optical nodes. The D10040300GTH operates from 40MHz to 1 GHz while typically maintaining 30dB or better of gain across the entire frequency range -- an industry first among available power doublers. The D10040300GTH helps cable operators to upgrade existing distribution networks to 1GHz and enables bandwidth-intensive services such as high-speed data, voice and HDTV. Operators can also exploit the linearity of the device to reduce the number of amplifiers in the network.
The OS10040320PW is a 1GHz hybrid high dynamic range optical receiver module designed for use in HFC optical nodes and deep fiber network installations. The OS10040320PW contains a single-mode optical input suitable for wavelengths from 1290nm to 1600nm, a terminal for monitoring the PIN diode current and an electrical output with an impedance of 75 Ohms. The equivalent input noise current (EINC) performance of the OS10040320PW is among the industry's lowest at 5 pico Amps per root Hertz, typical performance, helping cable operators to implement "fiber deep" solutions as they upgrade to 1GHz networks. Specifically, by enabling the optical node portion of HFC networks to be placed deeper into CATV networks, the OS10040320PW minimizes requirements for more costly Erbium-doped fiber amplifiers (EDFAs).
Technical features of the D10040300GTH include:
- Industry-standard SOT115J package
- 30.5dB minimum gain at 1 GHz
- Extremely low distortion with typical CTB of -65 dBc and CSO of -65 dBc (79 channels, 52dBmV at 550MHz, 7dB tilt)
- Superior return loss performance
- 440mA maximum current consumption at 24 VDC
Technical features of the OS10040320PW include:
- Superior return loss performance of 17dB, typical
- Excellent flatness of 0.7dB, typical
- 260 mA maximum current consumption at 24 VDC
- Low EINC, typically 5 pico Amps per root Hertz
Availability and Pricing
Samples and pre-production quantities of the D10040300GTH and OS10040320PW are available immediately. RFMD expects initial shipments of the D10040300GTH and OS10040320PW to commence in the
RFMD's Broadband Transmission Portfolio
RFMD delivers a broad portfolio of high-performance RF components for broadband transmission applications, including line amplification and hybrid fiber coaxial (HFC) and FFTx networks. Among RFMD's extensive broadband transmission products are GaAs- and GaN-based CATV hybrid amplifiers, active and passive splitters, transformers, baluns, diplex filters, drop amplifiers and line drivers. RFMD's Broadband Components business unit applies the Company's Optimum Technology Matching® strategy and advanced module integration technologies to deliver its customers industry-leading broadband transmission solutions.
About RFMD
Headquartered in
This press release includes "forward-looking statements" within the meaning of the safe harbor provisions of the Private Securities Litigation Reform Act of 1995. These forward-looking statements include, but are not limited to, statements about our plans, objectives, representations and contentions and are not historical facts and typically are identified by use of terms such as "may," "will," "should," "could," "expect," "plan," "anticipate," "believe," "estimate," "predict," "potential," "continue" and similar words, although some forward-looking statements are expressed differently. You should be aware that the forward-looking statements included herein represent management's current judgment and expectations, but our actual results, events and performance could differ materially from those expressed or implied by forward-looking statements. We do not intend to update any of these forward-looking statements or publicly announce the results of any revisions to these forward-looking statements, other than as is required under the federal securities laws.
CONTACT: RFMD®
Doug DeLieto, VP, Investor Relations
336-678-7968
336-678-7001
